Seperate fan switch
Old 03-18-2019, 09:38 AM
Marty Moore
Marty Moore's Avatar
Default Seperate fan switch
Hey guys I'm new to the forum but have a question I want to add a separate fan switch and relay to my 08 gt. Is there another hot water port I can screw into thanks
Marty Moore is offline
Old 03-18-2019, 03:01 PM
08'MustangDude
08'MustangDude's Avatar
There are kits on eBay that has a sensor probe you push between the cooling fins, and
you set the temperature when you want to relay to trigger.
Not sure what's wrong with the one on the thermostat housing though... That is coming
right from the engine.
You will have to drill and tap another port somewhere to add a sensor.
08'MustangDude is offline
Old 04-11-2019, 11:39 AM
Marty Moore
There were melt down issues under fuse box it just took out the fan circuit since the temp switch just.goes to ground to the pcm can I unhook the wire from theTemp switch and use the temp switch to break the ground to fire a relay that would have a constant hot at the coil of the relay. Will this effect the pcm. Just a fix until I can really fix the issue under the fuse block
Injected97GT
15
12-04-2007 12:16 PM
89GT351
10-25-2007 12:27 PM
Toddman0025
05-18-2007 10:52 PM
dj1203
09-19-2006 02:27 AM
STANGNUM
08-06-2006 12:43 AM
Quick Reply: Seperate fan switch
