Voltage regulator wiring
I have a 1995 Mustang that wont charge. We found out that the voltage regulator wiring could be bad. We change the alternator, battery, and computer. Is there anything else that could be wrong with it??
These links are usually located near the underhood fuse box, which is called the Battery Junction Box. They are usually not taped into the harness, and are visible as slightly fatter than most wires, and about 4 inches long. If one fails, it's special insulation usually bubbles a bit and turns brown or black. Look for that problem.
