Motor bogs down, help?
This is a weird one.
If my RPM is high, around 5k, and shift from 2nd to 3rd or 3rd to 4th and floor it instead of it taking off like it should, it just bogs down and I have to let off and give it less gas.
Ive done a tune up on it and just put a new exhaust system in it but didn't put the o2 sensors back in.(getting those put in monday). Before i got the new exhaust system it still had the same problem so not sure if the lack of an 02 sensor is the problem.
Also new fuel pump 5k miles ago.
Any ideas on what it could be would be great. im sure theres someone out there thats had the same problem.
Good to hear! I’m going to be purchasing an 02 GT with a similar issue. So I’m trying to gather as much info as I can. How did you go about fixing the traction control? Did the button not turn it off? Was it a wiring issue?
