will this work/how much hp
im looking for roughly 280hp (hopefully)
gt40 heads and intake (possibly ported)
crane 444221 cam.. 216/220 duration @ .050 and .533/.544 lift
would that setup work or what would i have to do..i dont know much about it
would i need diff. rocker arms or anything like that?
my car is a stock 88 lx..speed density
thanks in advance
thanks in advance
RE: will this work/how much hp
lsa on the cam?
so far looks like itll work, but you wont see 280, prolly more like 250-270 just going off of what i know
diff valve springs/locks/retainers atleast, RRs would be a good idea along w. pushrods
get the heads cut for dual valve springs and screw in studs/guideplates if you wanna run RRs
well..this chart says it should be fine
https://mustangforums.com/upfiles/55...2D4E1C1795.gif
i dunno how to post pics lets see if that works
nope
nope
looking at the low duration and 112lsa if it were me and i wanted it id try it, but i cant guarentee itll run good like i can a few other SD cams
get that cam, worse comes to worse if it doesnt idle good you pm me, i tell you some ways to fix it that most ppl do not know about.
im not really "set" on that cam
i wouldn't be heartbroken if i had to go with a different one
but if i go with that one.. ill let you guys know how it works out
