New To this Whole Carb Set Up. Couple Of ?'s
Well I went to the "dark " side and bought my first carbed and auto car. This is a new beast to learn since I have never owned a carbed stang (many fi cars). I have a few questions for you carb guys and guys with auto's with stall conv. First question is why when I have the car idleing sometimes a little smoke comes out of the breather on the valve cover. Is the normal? Second for the tranny question, when I pull up to a stop light and put the car in first it does not want to move, and sometimes I have to give it more gas to get moving(and yes I did check the tranny fluid). Is that because the conv has to fill up again? This is not my daily driver I just take it out a few times a week to run it. Sorry if these questions seem stupid but this is all new to me. Here is a build sheet I got from the guy:
ENGINE: 351 Cleveland bored .30 over making it a 357
11:1 compression
arp bolts throughout
new crank, shot peened rods (good to 700hp)
8 qt. moroso pan
speed pro forged flat top pistons with power seal rings
comp cams double roller timing chain
cam is a lunati SOLID ROLLER 51102LUN .608 LIFT 248 dur.
comp solid roller lifters
trick flow hardened pushrods
HEADS:1971 cleveland CLOSE CHAMBERED ported, matched
harland sharp 1.73 roller rockers
manley valves 2.19 intake 1.71 exhaust stainless steel
springs are lunati double springs with dampeners
Intake is a real, original PARKER FUNNELWEB from Austrailia
CARB : DEMON carb double pumper 850cfm
hooker headers full length adjusted to fit the car 1 58 tube
SPINTECH PRO SHOOTOUT mufflers that end at axle, 3 inch
MSD pro billet dist and 6a box accel wires and coil
TRANSMISSION:C6 B&M clutchs and bands, Cheetah reverse full manual valve body b&m shifter
STALL converter is 9 inch 4500rpm stall (3000 footbrake)
REAREND: 4.30 richmond gear with full size SPOOL
superior 31 spline axles with c-clip eliminators
9010 front 5050 rear lakewood shocks
Thanks for any help!
11:1 compression
8 qt. moroso pan
With a 4500 stall converter you would have to give it a little push from a stoplight but you should be able to feel the car in gear. As far as the smoke coming from the breather on the valve cover goes I'm pretty sure on this build it has a double breather with no PCV. The engine produces pressure in the bottom as the pistons move up and down. If the engine is in good shape you shouldn't see much coming out of the valve cover breather. Here's the low down, You bought a drag car in street car trim. Buy some tools because you will be needing them. If you are not knowledgable about cars you need to unload this one.
