Intake/ heads/ cam set up // not tech!!
well first i would convert to maf sensor that way it gives you more cam options, your going to hear a custom cam is but but a good off the shelf is the trickflow stage 2, heads anything from afr, trick flow, edlebrock if you plan on staying in the 302-306 range with motor dont go over 185cc heads i think and intake i havent researched much so i really can help you there
That's a pretty good start! But I have an 87 with gt40 crate with bcam and edelbrock performer intake 75mm TB still SD the key is stay 19lbs inj and cross your fingers. It isn't the cam as much as the inj size really! But yes I plan on going maf since I get lean up high where I can use larger injectors!
you all may think this is a crazy setup, but im running an Edelbrock Victor EFI, World Windsor Jr's 180's with bigger springs, and the cam is a NX-Comp-274, the nitrous blower cam. now, i have sacrificed alittle torque out of the gate, but im 4.10ed out back so that picks some of it back up. and my car ran 11.90's na. so you tell me!
junior04
09-28-2015 10:53 AM
