Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
what cam is best?
Old 01-18-2012, 11:46 PM
DaBears1983
DaBears1983's Avatar
Default what cam is best?
Hey guys I gotta 87 gt vert with the speed density setup. Searchin around and seeing that cam selection isn't the greatest. I was wondering what cam I could use that would be best fit for me...shorty headers,o/r h, flows
DaBears1983 is offline
Old 01-19-2012, 06:20 AM
AdderMk2
Banned
AdderMk2's Avatar
the stock cam will suit you best. Convert to MAF and get a set of heads and an intake first.
AdderMk2 is offline
Old 01-20-2012, 09:09 PM
DaBears1983
What's the best way to convert to MAF?
Old 01-21-2012, 05:48 AM
DaBears1983
I see online that there are tons of diff setups I could go with...I am wanting to go with a cam, gt40 heads an intake so would a stock MAF conversion be ok? Or would it justify an upgraded MAF? Just asking cause I don't waNna buy twice ya know
Old 03-19-2012, 03:09 PM
Venomantidote95
Venomantidote95's Avatar
You need a MAF ecm and brothers performance sells a pigtail MAF harness you have to hook it in and plug it up with those heads and intake , cam selection stock meter and injectors will be fine! get an adj regulator and bigger fuel pump also!
Venomantidote95 is offline
Old 03-20-2012, 01:32 AM
tinman
tinman's Avatar
The 'perfect' cam has never existed, ever............
tinman is offline
Old 03-20-2012, 01:47 PM
Venomantidote95
you can only get close lol! you have to take in a many different things, Heads, intake, induction capacity, car weight, rear gear, what you want the car to do, the idle you want, the tranny type, static and dynamic compression im sure i missed a few but that covers most to get as close as you can to the right one!
Lift and durations can get you the flow numbers you need but the lobe seperation will affect things like dynamic c/r and idle, and vaccum! It will take too much time and space to accuratley explain it so you will need to talk to your cam supplier!
Old 03-22-2012, 01:25 AM
tinman
tinman's Avatar
I went to a seminar about cams many years ago, put on by Crane.
The enginneer type that gave the class told me that if I changed car weight by 50# that it would effect the camshaft.........
tinman is offline
Old 03-22-2012, 08:12 PM
Venomantidote95
It is more complex then lift duration and sound LOL!
Old 03-26-2012, 08:59 AM
TTaylor
TTaylor's Avatar
Keep duration below 220.
TTaylor is offline
Quick Reply: what cam is best?
