Steeda Upper Control Arms & Chassis Mount
http://youtu.be/HdsITMgsJZ0
http://www.steeda.com/store/steeda-m...ntrol-arm.html
Shoot me a PM if I can be of help with these.
Need to reduce wheel hop and improve traction? Steeda's upper 3rd links will do the job. The Steeda adjustable upper 3rd link for S197 Mustangs gives you the ability to set your pinion angle and eliminate the torque deflection associated with the factory piece. This upper 3rd link uses our track proven three piece bushing package using soft outer bushings a hard center bushing on the axle end. This proven combination helps control axle wind up, wheel hop under acceleration, and allows for proper articulation without deflection for improved handling and cornering stability.
Product Benefits
• Adjustable pinion angle for optimum traction
• Better handling with more stable cornering
• Three piece urethane bushings for better traction
• Competition tested & proven
Product Benefits
jwog666
12-27-2021 08:09 PM
09-24-2015 09:18 PM
