Steeda Autosports Steeda Autosports is Ford's #1 aftermarket performance parts manufacturer. Steeda's parts are manufactured to ISO-9001-2000 standards and are thoroughly tested and proven on race tracks and on the street. Specializing in suspension and performance parts. Steeda also carries a variety of outside vendor products making Steeda your one stop shop for performance!
Steeda's S550 Billet Aluminum & Delrin Reverse Lock-Out Collar (GT/EcoBoost/V6)
Old 04-18-2016, 07:43 PM
tj@steeda's Avatar
Default Steeda's S550 Billet Aluminum & Delrin Reverse Lock-Out Collar (GT/EcoBoost/V6)
You asked and we listened! Our Steeda S550 reverse lock-out collars are available in billet aluminum or delrin, sure to match any interior!
http://www.steeda.com/steeda-s550-mu...t-v6-555-7080/
http://www.steeda.com/steeda-s550-mu...t-v6-555-7081/
Product Benefits
- Completely replaces your flimsy plastic factory reverse lock-out collar
- Avoid losing reverse capabilities due to broken factory lock-out collar
- Solid one piece design
- 6061 brushed billet aluminum or delrin for strength and style
- Easy installation, only takes minutes
- Steeda quality, lifetime warranty
- Made in the USA
The one big downside to the S550's stock reverse pull up collar is the materials used are cheap and wear/break after prolonged use. The plastic components in the reverse lock-out mechanism on your GT, EcoBoost or V6 shifter were not made to stand the test of time or prolonged use, once broken you will find yourself stuck and unable to engage your pony into reverse.
Our Steeda S550 Mustang Billet Aluminum and Delrin Reverse Lock-Out Collars are a solid one piece replacement for your OE factory lock-out collar. Our lock-out collars are sure to match the interior of your 2015-2016 GT, EcoBoost, or V6 Mustang. You will not need to worry about getting stuck without reverse capabilities, our billet aluminum and delrin reverse lock-out collars will take the abuse and are backed by our Steeda lifetime warranty.
Best Regards,
TJ
tj@steeda is offline
jgordon
04-16-2016 04:53 PM
FordTrax
04-06-2016 12:04 PM
03-28-2016 09:40 PM
03-18-2016 09:51 PM
02-14-2016 09:38 AM
Quick Reply: Steeda's S550 Billet Aluminum & Delrin Reverse Lock-Out Collar (GT/EcoBoost/V6)
