@ the track w/ the new turbo kit
I would get it back to the dyno. Looks like something isn't right. Your 60' isn't great given the tires, but it still isn't bad enough to land you with low 13s and high 12s with that low of a trap. The only other thing I can think of is maybe your hitting boost past the 60' mark, then losing traction?
boost leak sounds about right to me
but that's just me speculating... at the track running hard on a fairly new single turbo setup, meh, I could see some plumbing working a little loose
I thought I would throw a guess out there to see if I'm right or not xD
with that 60' and low trap speed and my inability to see the time slip cuz i'm at work, heh, i'm thinking maybe you are just spinning a ton through 1st and 2nd. How much MPH is he picking up on the back end?
edit... also... what RPM are you shifting at OP? Maybe you are shifting too early and falling out of boost?
Got a dyno graph for us to look at?
he is in FL, at 10:30pm on 11/11/09.. if he was at orlando speedway it was 1211 because of low pressure at that time. still doesn't have enough DA to change his time that badly.. especially running boost..
The op has to get some control arms if he wants to improve on his 60'. I was at the track with a guy with a twin turbo set up making 500/580 and had no suspension work. During the burnout it looked almost like his wheel was going to come off because of his axle going in all different directions. And he couldn't do better than a 12.5.
Op, where is the turbo mounted? I know of one guy who couldn't turn in a good time b/c he had a rear mounted turbo and it wouldn't get hot enough for the track. That would explain the low trap and picking up a lot on the big end once the turbo finally gets some heat.
