Nearly Stock Mustang Mach 1 goes 12.54
#51
RE: Nearly Stock Mustang Mach 1 goes 12.54
ORIGINAL: tripsevn7
[sm=burnout.gif]i absolutely agree that rubber is a major playa in solid times, but i haven't seen many if anyone lose that much time off their 1320 without suspension mods to go with the tires.
ORIGINAL: SilverBullet5.0
In his defense, tires make a huge difference in the quarter mile. Every tenth of a second you shave off your 60 foot equals about a tenth and a half at the other end.
So sya you get a 2.2 60 foot and run a 12.6. Its very possible that you can end up in the 11's with a 1.8 60 foot.
hes a friend of mine.
#52
ORIGINAL: Sidewayz6.0
I think you're smoking something. Keeping in mind I've done a 2V. He's got FULL exhaust, a chip, pulleys, throttle body and plenum. Trust me, he's at 300. The only reason he wouldn't show 300+ on a dyno is because of the gear. But he's there.
At the MOST 270-275 RWHP, and thats pushing it with a friendly dyno. I am making 280 RWHP with the below mods (minus the TKO and clutch/driveshaft). Hell, most of the full exaust/intake bolt cars I have seen only make somewhere around 260 or so RWHP.
It is competely impossible for a 2v GT to make 300 RWHP with no engine work, no cams, and no nitrous/boost. This has never been done before, and if you get a 300 RWHP dyno from a exaust/intake bolton GT you should get a better dyno shop. If it still nets 300 RWHP, call MM&FF for your car to be featured as the "factory freak of the century".
! You should be banned from the 2v performance section for sure!
#53
i would hardly attack anyones knowlege, but i think one could get close to 300 with lts,mid,catback,intake,pl,tb,maf,tune,ignition,etc . maybe not at tree hundred, but high 280-290 assuming gearing doesnt actually yield a lower dyno #
as far as banning anyone from anywhere, why not leave that to us, another question though, do you do your work or are you a buy it and have it installed guy?
#55
ORIGINAL: tripsevn7
Check out last months MM&FF, there is a 2v in there with cams and I think port work, and he is making somewhere around 300 to the wheels.
I have done all the work on the car except the cam install (didn't have the custom tools re: springs, or the time) and the TKO install (was more convient to get it done at the shop). And I already swapped out a T-45 for another t-45 +clutch etc myself before the second T-45 broke and I bought the TKO. And what difference would that make anyways? Its simple common knowledge.
I think you need your sarcasm meter adjusted (turned on?) about the banning issue.
If you really want to continue arguing a point that is already common knowledge, throw Code3GT a P.M. , and he can set you straight. If anyone on this site knows what power a 2v should make with what mods, it would be him.
#57
actually i talk to code and a number of others to boot, just as i have had two 4.6's a 4.9(current) and a true 5.0(current which is a pos 305 tpi) now i know this is hard to believe for ya, but i have a friend who has dynoed in the 280s w/o cams on a mustang dyno. i will get copies of his dyno sheets and post em when i get back in touch with him, boat captain
#59
depends on your definition of nowhere[sm=smokin.gif] damn if i could get a hold of chris, i would get his sheets, full bolt on, msd,custom tune,etc etc and he is just above 280hp
#60
Link about the car in question
This car is a freak and the driver is no slouch. I ran 13.31 @ 105 with k&n only.
