Baer ss4+ or aerospace component brakes
anyone using either of these systems?or know someone who is ? will be used for street and some dragracing..will be stopping 3400 lb with driver 1100 hp car.i do not want to go dragbrake set-up due to rotor warp with constant brake use.thanks.
My friend has an 8-second true street Mustang with Baer brakes, and he's a WD. I can put you in contact with him if you want. You can PM me here or send me a facebook message at www.facebook.com/TeamUPR
thanks for the reply...i had read an article in racepages about the baer brakes.and that is what i will be going with after talking to my fabricator friend.he is not a big fan of aerospace brakes.
Your OEM brakes will be fine and stop you 100% as well*, with the following changes:
1. A good set of pads
2. An upgrade of fluid
3. SS lines at all four wheels
Take a look at Upgrade brakes ~ Speeding up slowing down and will answer your questions.
Jazzer
*exceptions being found on the extreme end of braking needs
Jazzer
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
