help qa1 full front suspension having problems with rubbing
hi i have a 2002 mustang gt that i put qa1 front end wich includes qa1 k-member qa1 cotrol arms qa1 coli over kits camber caster platets and camber bolt kits for more adjustment . took it to a alighnment shop and set it to factory setting camber bolts and camber caster plates are all the way out to get the right adjustment . now the problem i am having is that the spring is so close to fram of car that when i go over some bumps like speed bumps and when i turn all the way to left the spring rubs on fram can some one please give me some advice it making me crazy thanks to all who respond
I understand that you have a 2002 Mustang. What I'm telling you is that the 79-93 arms will physically bolt onto your car. If the person who sold you your suspension mistakenly sold you Fox length arms rather than the 1994+ arms, it could cause clearance issues with the coilovers and frame rails.
