Suspension Ask all of your general suspension questions here!
Best rearend for a turbo stang
Old 07-18-2013, 03:22 AM
br.m.94
br.m.94's Avatar
Default Best rearend for a turbo stang
OK sometime in the near future i plan to build myself a twin turbo motor..havent decided if i want a SBF or BBF. anyway regardless i want to know what is the best set up. I will mainly be using this car on the street to scare the poop out of my passengers. i am going to have a 6 point roll cage with bucket seats and harnesses..yes i am going to have my rear seat in and harnesses in the back also (dont judge me) so itll be a luxury car weighing in at about 4000 ish pounds. ok now the motor i PLAN & HOPE on making it a 1100 HP(to the crank) Pump gas demon. With brake and tranny lock. i havent looked into the transmission just yet but i am going to get a custom built AOD 4 Speed to handle the power and i am going to want 4.10 gears with a 4 link and coilovers all around. ok now my question is with 1100 HP to the crank I know that not just any rearend can handle the HP specially when launched off the trans brake. And from what i understand posi is a no go..however i am stubborn and i am sure i can run a posi with 1100 HP i just need the be stirred on the right direction..any helps guys?? thank you!!
oh and ill be running on an 1/8 mile track most of the time until i get practice and then run on a 1/4.
br.m.94 is offline
Old 10-25-2013, 03:51 PM
84CopperGT
84CopperGT's Avatar
I would honestly go with a 3.55 or 3.73 over 4.10s. I had all 3 on my old turbo 04 and the 3.73s worked best.
84CopperGT is offline
Old 10-27-2013, 03:15 PM
uberstang1
Chupacabra
uberstang1's Avatar
If your only using it on the street rear will hold up fine, car will never come close to hooking on the street launching of a trans brake. Not even close. A ford 9 inch will be fine, plently of posi/lockers/ LSDs that will hold that power just fine, prob be in the ballpark of 800-850 rwhp once u go through the rear and auto. Gear selection depends on tire size.
uberstang1 is offline
Old 10-27-2013, 11:59 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
I run a Strange 9" in my car with similar power, no reliability issues. I believe Strange just came out with some new 35-spline differential. I run a 40-spline spool in mine.
Side note- I'd urge you to reconsider putting passengers in the back seat with a roll cage. A true rollcage will be far too easy for them to hit with their noggin' in case of an accident.
UPRSharad is offline
Old 11-02-2013, 09:35 PM
84CopperGT
84CopperGT's Avatar
Off topic but you should have padding on any roll cage pipe that you might hit in a wreck. Its cheap and trust me its worth it
Old 11-05-2013, 06:16 PM
uberstang1
Chupacabra
uberstang1's Avatar
Regarless of how much padding, still shouldn't have kids in the back though.
TCStangerv6
10-11-2015 05:57 PM
Bokeo
10-10-2015 08:28 PM
mdj89
10-08-2015 09:16 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
67LimeCoupe
09-21-2015 06:34 PM
Quick Reply: Best rearend for a turbo stang
