Where to buy IRS camber bolt?!
I picked up a used Cobra IRS last week and plan to install it in my 2000 GT. I lucked up and found a guy parting out a 2002 with newer 3.73's and stage 3 half shafts & I was able to get everything needed for the swap including exhaust, shocks, bolts etc.
Well.. The owner of the car atempted to remove the IRS unit himself before I arrived and with little to no knowlodge of it he started by removing the caliper and spindle. Luckly he gave up rather quickly and only removed a couple of bolts. However, he did end up loosing the drivers side camber adjustment bolt (top spindle bolt).
The bolt is an M12 1.75 with a special lobe shaped washer. A normal bolt/washer will not work. I tried. I spent most of the day today searching parts stores, dealerships and now the internet for a replacement bolt with no luck. I did find one on ebay for a jaw droping $50.
Does anyone know where I can find a replacement bolt? or know the OEM part number for them? Im stumped.
Thanks guys
Thanks guys
maestro1024
09-21-2015 02:40 PM
trashxtrash
09-20-2015 10:49 PM
09-17-2015 07:57 PM
09-16-2015 07:53 PM
