How to increase Lateral Gs in 2015 GT?
What determines Lateral Gs / high? Tires, suspension? I see that base GT / 2015 is 84, not so good. Would it increase significantly with high performance summer tires and maybe the Ford Racing Handling package? Maybe hit 95-98 lateral gs? Ger.
Increasing 2015 GT Lateral G's
Originally Posted by mungodrums
(Post 8506490)
These are my recent Autocross numbers. This is on concrete rounding 75 to 80 foot radius' and slaloms at about 40 mph. The Bridgestone RE71R's are rated at 200 treadwear. My GT came with the performance pack. I've added Koni Sport shocks and an Eiback front anti-roll bar. I've set the front toe out 1/16". The rear toe is neutral. The rear camber is at - 1.5. I run with the Traction Control turned off. The car magazines rated the stock (asphalt) lateral g-force performance at 0.94 g's. The track surface and tires are big factors. I'm running 285 X 35 X 19 tires on the rear and 265 X 35 X 19 up front. |
What you want to do will definitely increase it.
Unless you plan to compete where there are rules limiting wheel width, include wheels that are at least 10" wide all around in your plan. If you ever plan on running 305-wide tires, go with 10.5" or 11" even if you're only thinking in terms of 285's now.
If you insist on running staggered tire or wheel width sizing, less stagger is better than more until you get into forced induction levels of power. Compare the wheel & tire sizes that Ford now uses in their Performance Pack Level 2 option for the GT and the GT350/GT350R. They're much more seriously intended than Performance Pack (aka Performance Pack Level 1 or PP1) wheel widths and tire sizes, which in turn are a step beyond base. As mentioned, there are gains to be had in alignment . . . alignment settings that shouldn't be too aggressive for your average driving particularly with respect to toe. Norm |
mongodrums, it would take to long to explain "chassis geometry" which is what you need to understand in order to answer your question. So here is a link to a great article which any "road course" racer should familiarize themselves with. https://nasaspeed.news/columns/drive...ecar-dynamics/ Yes, it took me many years of "stock car" racing to begin to get a handle on racing suspensions.
Camber settings for track days??
I was wondering if there is anyone else that has significant improvment in handling with adding negative camber? If so what are you setting it at and what kind of suspension do you have?
Originally Posted by Jarrett Pablo
(Post 8650027)
The earlier comment was great. There are really good references for suspension setup and tuning. My biggest suggestion is to review these and remember that anything you do to tires, wheels, springs, etc. will probably change up your last best setup condition. Some of these changes much more than others. I'd pick up a $20 book on suspension setups before investing in hundreds or thousands on your suspension. |
mungodrums, if you are really interested in road course suspension geometry, I would strongly suggest you start your learning experience by reading the Motorbooks International "PERFORMANCE HANDLING," How To Make Your Car Handle Techniques, by Don Alexander. This is a excellent publication for beginning "road racers."
Best books I remember reading are Carrol Smith's Engineer to win and Prepare to Win. Rather old-school but still a wonderful background as to WHY we do various things. You will figure out why an old Trans Am class car like a restored '70 Boss Mustang, or 70-71 Javelin can still kick butt.
Try on line or Motorbooks. |
the higher the car is the higher the center of gravity is and more body lean. Lowering springs and some GOOD (don't buy cheap) high quality struts and springs in the rear can help. don't forget your sway bar bushings, they might be a little worn and some new poly ones will stiffen it up... but you'll also notice the ride will become more jouncy....
