H&R springs 2-3" gap?
https://cimg2.ibsrv.net/gimg/mustang...c9eca18d3d.jpg
Thanks for the add just joined up today and have a question. I have an 01 Bullitt that I have owned for about 5 yrs and have always thought something was wrong with the front suspension but never looked into it. Car is lowered with H&R springs they are either the Sport or Super Sport I have to check the part #. I also am not sure if there are isolators installed. I have the springs, Bilstein struts, MM castor camber plates and a 2-3" wheel well gap. What could be the issue as for tires I am running 265/35/18. Rear of car sits as I feel it should but the front looks off. |
Originally Posted by Bullitt_01
(Post 8643000)
The nose would be lowered by 1", which would give a noticeable amount of 'rake' as long as the rear tire diameter was left stockish at about 27". 265/35-18 is too small for a Mustang in terms of load capacity - it's 4 index numbers smaller than what Ford typically installs as OE (it's a 93 SL tire vs 97 SL, SL meaning "standard load"). You may be able to "crutch" this by increasing front tire inflation pressures by 4 psi or so, which will probably trade higher than normal carcass heating using Ford's door sticker pressure for higher than normal center-tread wear. Of the two, tread wear is the less serious way to go wrong. Norm |
