i have a ?
i have a 89 2.3 and just got a fully built motor,tranny and wiring harness out of an 85 svo,will the svo engine harness swap over to the 89?these 2.3 are new to me.
also,my car has a map sensor,do i use that or do i need a bap sensor?thanks guys |
The whole wiring harness for the engines main functions run right from the computer and connect o the 2nd harness on the driver side.
As long as it plugs into the other harness your good to go. You can use a MAP but you need to take the vacuum line off it |
Originally Posted by sleeper_inc
(Post 6367464)
As long as it plugs into the other harness your good to go. You can use a MAP but you need to take the vacuum line off it cool,thanks |
It would easier to if going to turbo on the 89 to use the vam connection only and repin the computer.
Stinger has site with repin info. and this one I like. Reason I like it even add the info for egr valve if need say to met local smog rules. http://www.flemworld.com/ |
Originally Posted by mg man 75
(Post 6370910)
