2k to spend????
2k to spend????
hey guys i have an 04 cobra and it already has a cat-back and a x pipe on it and i am going to be putting 2k into it just wanted to know what i should get give me some suggestions?????
RE: 2k to spend????
Pulley, tuner, tunes from a reputable place, Drag radials, IRS Brace, New idlers, Heat exchanger, new shifter, rear seat delete kit, wideband A/F monitor. O2 bung welded in, Boost gauge, temp gauge, oil pressure guage, Guage pods, Nitrous kit. Other IRS upgrades. Blower port, 60lb injectors, KB Boost a Pump.
Just throwing out ideas.
Happy shopping
Aaron
Happy shopping
Aaron
RE: 2k to spend????
here's a freebie. Don't know how well/reliable it is but I've read about it on other forums as well.
http://www.rpmoutlet.com/boost%20bypassc.htm
RE: 2k to spend????
Sounds like you are off to some good suggestions!! I would consider a blower port,TB and plenum port match, upper/lower pulley combo (which will get you over the 500 rwhp mark!) IRS brace, JLT CAI, fuel and boost guage, a/f fuel guage if ya have the funds (these get very expensive), good set of drag radials, aftermarket heat exchanger to dissipate the added heat,
good shifter (Steeda or MGW), H&R race springs. And most importantly A GOOD TUNE!! Let us know what you decide!!
RE: 2k to spend????
yeah the wedding went pretty crappy invited a bunch of dead beats. so i'm just going to do the pulley and a tune. I am very literal so i need to know what i should get and what type of gains i'll be seeing. Word for Word from experienced people that already have it done to their 03-04 cobra. Tell me what you got for a pulley and i have heard that SCT is good for the tune.
RE: 2k to spend????
If you want to play it safe, for now? Get a 2.8 Reichard Racing non-slip upper pulley ( the best on the market!!) And get an SCT X-Cal 2. It comes with a pulley tune that should be safe for your 2.8 upper pulley! Do not exceed this boost level with this tune! This should suffice until you do another major upgrade! The good thing is that your X-CAL can upgrade your computer, no matter what mods you do in the future!
