How do I get the s/c pulley off my 03 Cobra?
RE: How do I get the s/c pulley off my 03 Cobra?
ORIGINAL: Hisss04Cobra
I just ordered my pulley and chip. Should I go ahead and get the some new plugs?
Make sure when you install a blower pulley, you take it flush with the snout!! Alot of people don't do this and begin shredding belts! This gets xpensive fast!! I purchased a Metco Motorsport pulley puller and install kit. I help a lot of the snake owners around here, swap pulleys and upgrade their cars.
The plugs are easy to change. They are under the covers on the valve covers. Just take out the 2 bolts on each one and lift it off and the coil packs are underneath. Pull the coil pack off and the plug is under it. Be gentle taking the plugs out and installing the new ones. If you cross thread it in the aluminum head youare in big trouble! I recommend the ngktr6 plugs. I was having spark knock with my stock plugs after the pulley swap, but the ngktr6 plugs solved that.
ORIGINAL: Dan04COBRA
Billetflow's removal tool is the ABSOLUTE BEST offered.
I have a puller from Pulleyboys. Cheap & it worked just fine.
http://www.pulleyboys.com/fordsvtpt.html
11-10-2015 11:39 AM
