installing a prochamber and heat exchanger
I am going to be installign both of these things tonight and tomorrow anyone who's done it before got any helpful hints or advise to share to make the job easier?
RE: installing a prochamber and heat exchanger
For the prochamber, You'll need a universal extension or swivel for the passenger side 15MM nuts. Also, put some WD40 or Liquid wrench on the nuts before you start the project. Makes things a ton easier. Be nice to the passenger side when removing the stock mid pipe so you can reuse the factory gasket. It works much better than the one MAC provides. For the HE, I think its pretty straight forward. Just have your bucket ready to catch the coolant that comes when removing the stocker. When refilling, pour slowly to avoid getting air in the system. Use the same brand and coolant type when refilling. Make sure the water used for mixing the new coolant is distilled water.
alright i have every extension in the book and just cant get a good enough angle to get the lower bolt off on the passenger side any suggestions on how to get it off?
i am giving up for tonight, going to the track in the am, but i'll go at it again tomorrow night. just can't quite get the socket to hold tight on that bottom nut right when it feels like it's about to turn it, the angle of the extentions causes it to pop off. frusterating to say the least.
