Aluminum drive shaft wear
98 Cobra-
Over the weekend I noticed a vibration at my feet that I hadn't noticed before. It occurred under 3/4 to full throttle in 3rd gear. Felt like my drive shaft might be rubbing against something. This evening after work, I crawled under it and there is a fairly deep groove in my drive shaft. It is being dug by the parking brake cables bracket. There is about a 3 inch clearance, but the bracket shows wear, too.
The drive shaft does not look warped and nothing feels out of balance. Can my suspension be giving that much under acceleration? I did just install my supercharger.
Thanks for any insight.
RE: Aluminum drive shaft wear
Your ride height is the problem. Lowering a mustang 2 or more inches can cause the ebrake assembly to rub the driveshaft. I dont know how to fix that problem though.
Hey I think i am hearing the same noise. Does it sound like a humming noise(almost sounds like your tires need balanceing). IT happens to me on the highway at around 55 to 65 miles per hour. Let me know if it sounds like the same problem.
99 cobra
99 cobra
ORIGINAL: hspurgeon
Would I lose a lot going back to a stock drive shaft?
[IMG]local://upfiles/9687/A37B8C92E0E547E295E34E8B77719040.jpg[/IMG]
09-01-2015 08:16 PM
