IRS Axle Swap?
IRS Axle Swap?
I have a 2000 GT Convertible.
A buddy has a wrecked (from the front)03 Cobra coupe.
Two questions for all of you:
1.) Is it worth it to swap the suspension from the Cobra to the GT? Is the ride much smoother, softer, harder?
2.) Is it a huge pain in the butt? What's involved (I have access to a lift and full tools and a mechanic)? Any parts I need to buy in advance?
Thanks!
Thanks!
RE: IRS Axle Swap?
ORIGINAL: GusinCA
Thanks!
Thanks!
RE: IRS Axle Swap?
I am more into comfort and handling than all out launch times.
So the consensus is that it would be good for me.
Maybe I should post a trade? Maybe there are people out there who want my solid axle in exchange for their IRS and save myself any money buying one?
RE: IRS Axle Swap?
1) depends on what your idea of "worth" is. Is it worth it in terms of comfort and cornering? yes...my buddy has an 02 GT and i can really tell the difference. My friends have been amazed at the vehicles ability to take turns without the tires slipping and the girls love it's ability to smooth road imperfections. In terms ofstrait performance? No, its more expensive to mod to handle the power and there is a much smaller market for it. It's a ton of money for replacements let alone performance modifications to it. You'll spend the first half of your money replacing bushings to control its wheel hop. It can be something special, but you need the money first, and Kenny brown isn't in business right now to offer the friggin awesome re-designed IRS setup and rear steer kit (i'm already in line)
2)It's not much to drop itin https://www.trademotion.com/schemati...cal/FWP110.gifas you can see by the mounting points, you should definitally be able to do it...if i was to offer any advice on what do first, press any old bushings and upgrade anything before you put it in, i would advise on differential bushing (marked 6 in the diagram) as it is usually the first to cause severe damaged
RE: IRS Axle Swap?
Thanks for the detailed reply.
So you're saying the ride is smoother and it corners better - that is exactly what I want.
I'm more of a canyon carver than a drag racer.
So besides bushings, there is no other modifications necessary? No modifications to the exhaust orbrakes?
RE: IRS Axle Swap?
the exact opposite there's a TON of 03-04 cobra's wanting a solid axle swap (you'll be surprised at the price a solid goes for) for their drag racing projects...you've got a bigger market than you think, and if you get the whole axle, the mounting points for a cat back are on it...and you'll be set with a cat back
