SVT Forums
1999 cobra lots of mods 21,000$ is it worth it?
Old 06-21-2007, 11:44 PM
kingleo1983
kingleo1983's Avatar
Default 1999 cobra lots of mods 21,000$ is it worth it?
99 Ford Mustang Cobra (35th anniversary edition) convertible. Triple black
Navigator Power Heads long block
72lb injectors
canton oil pan'
hooker header and x pipe (off road)
spec stage 3 clutch
aluminum fly wheel
3,5 inch univer upgraded to disc blower
plasma booster
raptor shift light
inn.west 10% over balancer
Anderson power pipe
max ms subframe connectors
bassani exhaust
weldon pump regulator and filter
return style fuel system
aluminum drive shaft
steeda short throw shifter
ati pro charger
brembo rotors and calipers
HRE wheels with BFGoodrich Gforce TA tires. Front has 265/35/18 and the rear has 295/35/18
5 way adjustable tokiko struts
lowering springs
373 gears
boost end fuel pressure gauges
ground designs 2000 black widow body kit (includes hood, spoiler, front and read bumpers, side skirts and a tonneu cover. When the tonneu cover is put on it makes the car a two seater.
kingleo1983 is offline
Old 06-21-2007, 11:59 PM
02 Stang
02 Stang's Avatar
Default RE: 1999 cobra lots of mods 21,000$ is it worth it?
Miles?
02 Stang is offline
Old 06-22-2007, 12:20 AM
Ahnial8u
Ahnial8u's Avatar
Probably not!!
Mods do not increase the value 9 times out of 10. Have you seen the car? That Body kit looks horrible. 72 LB injectors 700+ horsepower??
Buy a Termi you wont be dissapointed.
Ahnial8u is offline
Old 06-22-2007, 01:06 AM
kingleo1983
It has 32,000 miles on it, its supposlivly dynoed at 640 Max hp and 588 torque
Old 06-22-2007, 04:45 AM
xxkazp3rxx
xxkazp3rxx's Avatar
for 21k i wouldn't touch it with a 10ft pole... that car I GAURENTEE has been beat to death... That car isn't worth more then 13-15k... You might be inheriting someone elses project... for another 3-4k you can find decently used 03/04 Cobras, or get a regular 99 stock Cobra, or a SN95 (depending on the body style you like more) which you can pick up from 8-12k for SN95 or 12-15k for the 99... and put your own money into this way you know what it's done... and frankly, if you've never driven a car that fast - you probably will wreck it within 2 weeks.
xxkazp3rxx is offline
Old 06-22-2007, 02:05 PM
kingleo1983
I forgot to mention that the car had all the work done to the car at 25,000 miles he faxed me over all the information, so how much do you think he could beat on it? thanks for the info
Old 06-22-2007, 04:42 PM
Ahnial8u
Ahnial8u's Avatar
Is this gonna be a Daily Driver?
It seems as if you have already made up your mind so if you go ahead with the deal good luck.
Ahnial8u is offline
Old 06-23-2007, 12:20 AM
chrispy98cobra
chrispy98cobra's Avatar
in 7k miles he could have blown it up twice..........for sure its been beat, save another 2-3k and get an 03/04
chrispy98cobra is offline
Old 06-23-2007, 02:56 AM
POISND U
POISND U's Avatar
I'd passbecause ofthe gay *** body kit alone......[:'(]
POISND U is offline
Old 06-23-2007, 03:20 AM
Stang9946
Stang9946's Avatar
Aside from being beaten on, I wouldn't pay a dime over 16k
Stang9946 is offline
Quick Reply: 1999 cobra lots of mods 21,000$ is it worth it?
