Biggest tire that will fit a 99 cobra
RE: Biggest tire that will fit a 99 cobra
i know many people running 315's in the back, but i put my 295's on and was worried about the clearance between the tire and rear subframe bolt, so i got the low profile bolts and could squeeze 315's if i wanted to now
I have 295s on the back of my 03 Cobra on 18x10 Saleen wheels. They rub a little on the fender when I hit a big bump mid corner, but im sure a slegdehammer would fix that. Im not sure about a 305 or 315. If you're worried about traction, my 295mm Goodyear GS-D3s dont even chirp in 1st or 2nd gear and I'm making about 450hp. Im sure that same tire/size would be good for at least 550. Even when I dump the clutch at about 3000rpm in first, the clutch slips more than the tires do. Amazing tires!!!
You can fit a 10.5" rim w/ 315'son the back of the 99-04 Cobra, but you have to buy the bolt kit for the IRS. I have 315/35/17 Nitto's mounted on 10.5" FR-500's on the back of mine and I can barely fit a sheet of paper between the IRS bolt and the tire. I wish they made a 305/35/17, but I can only find 305's in an 18" size.[:@]
