T-56 Oil Change
T-56 Oil Change
Everytime I search for anything i get no results. Can anyone post a thread on how to change the t-56 oil and all the tools that are needed? Pictures are welcome. Thanks to anyone who shares info.
RE: T-56 Oil Change
Well, if it's anything the same as the T-45, and I'd expect that it wouldn't be too much different, just drop the drain plug out of the bottom like you're changing the engine oil, then you can fill either from the the top inside with the shifter off and just put in whatever the capacity is (don't know off the top of my head), or the way I've always been told is to use a pump and fill from underneath until you can stick your finger in and feel the oil.
Last time I did it on the GT I just filled from the top however much it was supposed to have and was done. I didn't have a pump laying around anyway.
RE: T-56 Oil Change
ORIGINAL: 562cobra
bump for anyone whose change it on a t-56. thanks though aj
I'm sure it's very much the same, but I'd like to hear a confirmation myself before I have to change mine.
RE: T-56 Oil Change
First of all, I hope your using Transmission fluid, not oil.
Go here. http://www.svtperformance.com/forums...d.php?t=152329
You will find a lot of how to stuff in there for your termie.
RE: T-56 Oil Change
ORIGINAL: AllVenom
TfcCDR
09-14-2015 12:08 PM
