Radiator fan doesn't come on (97 Cobra)
Does anyone know what would keep the cooling fan from turning on? The temperature gauge works fine and the fan spins freely by hand. Is there a relay somewhere that could be bad?
RE: Radiator fan doesn't come on (97 Cobra)
CCRM (constant control relay module) It's on the inside of your passenger fender. On the other side of where your MAF sensor is. You need to take the wheel off and pull out the inner liner to access it. I would check your fuses and conections before you get that far!
Turned out to be the CCRM. Had a shop pull it out and check it. He said it was the first time he'd ever seen one go bad, and all he works on is Mustangs.
09-25-2015 09:06 AM
