2001 Cobra with an Eaton
#21
RE: 2001 Cobra with an Eaton
VIA the Mach 1 registry.
This is a list of 64 parts that I put together after looking at multiple pics and from what I have gathered that will be needed. Some are small parts that you will get when buying the S/C or in package deals that you get. Makes a great checklist when making sure you got everything needed to complete the swap. See page 2 for pics of each part. It's not complete yet but will be when I get a chance to take pics of everything.
(6312) Crank pulley /Harmonic Balancer
(6312B) Supercharger Crank drive pulley
(8678A) Pulley w/mount Replaces stk. alt. Pulley on 99-01 Cobra’s and 03/04 Mach 1’s
(6B209B) Pulley bridge assembly for S.C. (bracket, 2 idlers, tensioner)
(8678B) Idler pulley,timing cover pass. side
pulley, timing cover drivers side
(6D080) Timing cover
(10A313) Upper alternator bracket
(10153) Lower alternator bracket
(10346) Alternator
1U2Z-14S411-TA Electrical connector (alt. to harmness )
(6B209A) Tensioner on timing cover
(8260) Radiator hose
(8A593) Radiator hose
(8K576) Radiator hose
(8548) Water cross over pipe
(6881) Cobra oil cooler adapter
(6A642) Cobra Oil cooler
(9002) Cobra fuel tank
(9H307) Cobra fuel pump
(6F066) Eaton supercharger
(9424) Lower intake
(6K775) Garrett factory intercooler
3U2Z-14S411-SSA IAT2 sensor connector
(9H308A) Intercooler hard lines that hug the block
(9N491A) Intercooler hard lines that come from the h/e
(9L443A) Intercooler line that goes from the i/c adapter to i/c res.
(9L443B) Intercooler line that goes from the i/c adapter to the hard lines that hug the block
(9L443C) Intercooler line that goes from the hard line against the block to i/c pump
(9L443D) Intercooler line that goes from hard line to hard line
(9L443E) Intercooler line that goes from hard line from h/e to i/c pump
(9L443F) Intercooler line that goes from hard line and connects to h/e
(9L443G) Intercooler line that goes from hard line and connects to h/e
(8501) Ford / Bosche water pump for intercooler
(8N500) Intercooler pump bracket
(8K226) Factory heat exchanger
(8A193) Heat exchanger mounting bracket
(8C386) 2each bracket clamps for h/e
(9N491B) Lower manifold to intercooler water adapter
(9A589) Plenum
DELETED TB SAME AS MACH
(9B659) Intake tube from maf to t/b.
(9F715) IAC valve
(9F593) Injectors
(6F089) Boost bypass actuator
(9A825) Cruise control cable
(9A758) Throttle cable
(9728) Throttle and cruise control cable mounting bracket
(12B579) MAF
(9D475) EGR valve
(9D477) EGR tube
(6C324) PCV tubing
(9F479) Sensor on the back of the S/C
(9J432) Bracket for vacuum stuff on left side of the S/C
(9H465) Vacuum stuff
(9J459) Vacuum stuff
(9J460) Vacuum stuff
(9E498) Hose's or tube cluster of connectors for the vacuum parts above
(9F670) IAC gasket
(6020) Timing cover gasket LH side
(6020) Timing cover gasket middle
(6020) Timing cover gasket RH side
(9H486) Intercooler to S.C. gasket
(9L437) Plenum to S/C gasket
(9D476) EGR gasket
ADDED:
Power steering resevoir bracket.
I/C resivoir tank
i/c pigtail
S/C 8 rib belt
inner acc. belt.
(10346) Alternator
(9424) Lower intake
(9A589) Plenum
(9F715) IAC valve
(9F593) Injectors
(12B579) MAF
(9D475) EGR valve
(9D477) EGR tube
(6C324) PCV tubing
(9F670) IAC gasket
(9D476) EGR gasket
ADDED:
I/C resivoir tank
i/c pigtail
S/C 8 rib belt
inner acc. belt.
11-10-2015 11:39 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
