Installed Brakes and I have a noise
So I installed new Rotors (R1 Concepts Drilled/Slotted) on the Front and Back and new Pads (Posi Quiet) and when i'm driving theresa clank noise like something is loose we took the tires off and nothing was loose so has anyone had this problem or know wat it could be?
RE: Installed Brakes and I have a noise
maybe you lost a slide for the calipers? Ya know those metal inserts the pads slide into. That little bit of movement can cause a clank or similar.
Check the metal shield to see if its rubbing.I did my breaks a month ago and had this problem.
We checked the shield and pushed it back just to make sure and that was not the problem...im going to check the inserts to see if we can make a noise w/ them
ok so heres the latest we have come to the conclusion that it is the brake pads they are smaller than the caliper, and they have some movement in there which can cause the noise..does anyone know how i can fix it besides getting new pads
