SVT Forums
99 Cobra HELP if you can??
Old 08-03-2008, 08:12 PM
ZZYZXXXX
ZZYZXXXX's Avatar
Default 99 Cobra HELP if you can??
Hi Guys,
I am about to buy this 99 Cobra Convertible...I just noticed that the front driving lights are completely gone. The mounting holes are still on the bumper cover and the wiring still seems to have the connector attached, so it looks like the lights were removed as opposed to stolen. What parts are involved in replacing these lights? I noticed the bezels I seen had two holes, one for the lights, the other is an air induction I assume? Was there any ducts or something attached to these maybe going to the breaks or somewhere else or were they just there for looks? Any specific help would be appreciated as this might be a deal breaker in me buying this Cobra. How much would adding the lights back in cost approximately? Thanks for your help with this.
Joe
ZZYZXXXX is offline
Old 08-03-2008, 09:24 PM
baino
baino's Avatar
Default RE: 99 Cobra HELP if you can??
Its nothing to replace the lights. I removed mine because I like the look better. All there is to replace is a little bracket with phillips head screws holding it in and the lights sit in there. You can even get different styles of lights on ebay, just make sure its for 99-01 cobra. There is no ducts for intake down there, however some kits like the JLT sit right behind those holes.
baino is offline
Old 08-03-2008, 11:06 PM
2012White5.0
2012White5.0's Avatar
The lights are pretty easy to put in as long as all the wiring is there. I did it on my old 97stang. As for the 2 holes on the bezels, one should be for the actual headlight and the other should be for your turn signal.
2012White5.0 is offline
11-10-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
Dan04COBRA
09-30-2015 11:46 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: 99 Cobra HELP if you can??
