What should my cobra be making?
My Terminator made 460rwhp/480lb ft tor with a 2.81, intake, and exhaust.. I've seen cars make as much as 480rwhp with those mods, and as low as 440ish... It's a hard range because some cars do respond better then others.. and it's also in the tune.. some cars are leaner then others...
But the market for the Cobra also includes: 4v is more efficient, higher rpm band, responds better to mods, the motor is also built, tq is higher... and the list can go on...
As a comparison, my '03 Cobra made 457/480 with a 2.90 upper, intake, catback, midpipe and Accufab TB. That is just a tad over the average. Assuming you are on 93 octane fuel and have a decent tune, you can expect to see 455-470rwhp with your setup. The tune will be the deciding factor.
You might consider porting your blower (Stiegemeier) which will not only get you to 500+ rwhp, but will make your Eaton more efficient and allow you to run more boost. With a 2.80 upper and a Stage 2 port my numbers jumped to 504/494. Just something to consider. However, if a twin-screw is in your plan then you might want to save your money. JMO.
Grabber - every Cobra is different... with a 2.81 pulley, catback and intake I made 440/480, or 460/480... I forget honestly... I just remmeber there was also 90%+ humidity.. and I know with the same mods there are cobras that have put down 470rwhp... can't go by what DOodad was making... That's why there is such a big gap between everything...
We had a cobra here in phoenix, make 464rwhp and 498 rwtq!
mods:
Cold air
bassani catback
mac midpipe
2.8 pulley
stock lower
fluidyne heat exchanger
Not all cobras were created equally... His car, BONE STOCK, put down 389rwhp...
mods:
Cold air
bassani catback
mac midpipe
2.8 pulley
stock lower
