SVT Forums
IRS Brake Calipers
Old 09-03-2008, 03:18 PM
Sxynerd
Sxynerd's Avatar
Default IRS Brake Calipers
Will 96 brake calipers fit onto a 04 IRS? I'm hearing mixed answers. I know the rotors are different but i'm unsure of the Calipers.
Sxynerd is offline
Old 09-03-2008, 04:36 PM
BraMas
BraMas's Avatar
Calipers are the same. Mounting bracket is different
BraMas is offline
Old 09-03-2008, 05:45 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Yea the calipers themselves are the same....Not sure of the mounting brakets...
WhiteFoxGT is offline
Old 09-03-2008, 08:16 PM
BraMas
BraMas's Avatar
The bracket if different to accommodate the larger rotors on Cobra's/Mach1
BraMas is offline
Old 09-03-2008, 09:01 PM
Sxynerd
Sxynerd's Avatar
So if the IRS has the bracket then I all I'd need to do is take my GT calipers off and put them on the IRS, am I correct?
I'm sleepy.... rough day at school!
Sxynerd is offline
Old 09-03-2008, 09:12 PM
mfj
Banned
mfj's Avatar
YES! CORRECT!
mfj is offline
Old 09-03-2008, 09:13 PM
ponysnake99
ponysnake99's Avatar
The mounting bracket is built into the knuckle and the calipers/hats are identical between gt's/cobras. It should bolt up with reletively no problem.
ponysnake99 is offline
Old 09-03-2008, 09:45 PM
Sxynerd
Sxynerd's Avatar
Sweet! IRS here I come!!!! I should be picking it up in a week or two when my wife can get the day off for a road trip down to Ohio. 900$, does that sound like a good deal? it's a 31 spline 04 with 12,000 miles on it. Bone stock.
Sxynerd is offline
Old 09-03-2008, 10:52 PM
BraMas
BraMas's Avatar
What? You need this bracket that bolts to the knuckle and the caliper bolts to that bracket
BraMas is offline
Old 09-04-2008, 05:58 AM
ponysnake99
Oops my bad, i took hat to be that bracket (wrong terminology too btw) and the actual mount on the knuckle that bracket attaches to be the "mounting bracket"
Matt's 95 Stang
10-05-2015 07:16 AM
ChampInSD
10-02-2015 04:55 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: IRS Brake Calipers
