SVT Forums
Radiator fan doesn't come on (97 Cobra)
Old 02-28-2008, 09:49 PM
Dilireus
Dilireus's Avatar
Default Radiator fan doesn't come on (97 Cobra)
Does anyone know what would keep the cooling fan from turning on? The temperature gauge works fine and the fan spins freely by hand. Is there a relay somewhere that could be bad?
Dilireus is offline
Old 03-02-2008, 12:20 PM
RuffCat
RuffCat's Avatar
Default RE: Radiator fan doesn't come on (97 Cobra)
CCRM (constant control relay module) It's on the inside of your passenger fender. On the other side of where your MAF sensor is. You need to take the wheel off and pull out the inner liner to access it. I would check your fuses and conections before you get that far!
RuffCat is offline
Old 03-05-2008, 04:18 PM
redeye
I ♥ Acer
redeye's Avatar
unplug the plug on the fan its self i found on my buddys car the plug was melted, and wasn't making contact.
redeye is offline
Old 03-13-2008, 02:54 PM
Dilireus
Dilireus's Avatar
Turned out to be the CCRM. Had a shop pull it out and check it. He said it was the first time he'd ever seen one go bad, and all he works on is Mustangs.
Dilireus is offline
Old 09-03-2008, 12:07 PM
ycats
ycats's Avatar
I replaced the CCRM on my '98 v6, fan still won't come one..........however, I keep blowing the fan fuse, so what do I need to do? Trace the wiring beginning with the fuse?
ycats is offline
Old 09-03-2008, 05:46 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Unplug the connector from the fan itself and check the harness... They burn up and melt..
WhiteFoxGT is offline
Old 09-04-2008, 06:59 AM
ycats
ycats's Avatar
I put the original fuse back in, it's a breaker so it just resets itself.........but figured out my problem, the fan has seized up, so I will have to replace it.
ycats is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
kevsgt
10-09-2015 10:12 PM
88 orangepeel notch
10-05-2015 09:03 AM
09-25-2015 09:06 AM
Quick Reply: Radiator fan doesn't come on (97 Cobra)
