03 Cobra Crossover Tube help!
Ok, I have a question on my 03 Cobra's Crossover Tube / coolent line: How do you get the plug off? Is it treaded? Worked on it for about an hour last night….getting ready to change the antifreeze…Maybe I should try to heat the plug up a little (corrosion?) Thanks, Tim
If it's the one I'm thinking you put a 1/4 in socket wrench on it with no socket on the wrench. Probably should blast it with penetrating oil first. You might even need a little leverage because most 1/4 in drives are small. And yes it is threaded in.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
11-10-2015 11:39 AM
