Eaton on 01 Cobra?
you'll need all the pulleys, the lower intake manifold, heat exchanger with all the plumbing, reflash your pcm, larger injectors, boost-a-pump or cobra pump swap. its gonna run you about 2k in parts, even used it'll be around 1,400....
not worth it IMO...
not worth it IMO...
Nice! what color is it and any mods? It's kinda hard being in college and working. I work a full time job and go to school. Sign up on SVTP and use the search button. Their were some threads about this topic on their with install guides. I'm to lazy to look lol. IMO....I would take the Eaton for free, sell it and then use that money towards a KB, Procharger or Turbo. Their is also a section just for 99/01 cobras.
Parts needed:
Lower intake manifold
Intercooler/bolts
Intercooler pump and bracket w/ all hoses
Intercooler relay assembly with PCM pigtail
Intercooler reservoir
Eaton EGR setup (bracket, sensors, vacuum connections, PCM pigtails)
MAP/IAT2 sensor with PCM plug in (pigtail)
03/04 Timing Cover with gaskets
Valve cover gaskets
Upper pulley bridge wth idlers/tensioners
03 serpentine tensioner
03 Alternator with all 3 brackets
Lower pulley cage
03 Harmonic Balancer
03 Induction assembly MAF and TB
03 IAC valve with pigtail
03 Alternator pigtail
All bolts, studs, gaskets and misc other little pieces.
Intercooler/bolts
Valve cover gaskets
Lower pulley cage
