03 cobra shutting off
03 cobra shutting off when i depress the clutch or put it in neutral, it did it twice tonight but thats it i was leaning towards an IAC valve but not sure just wanted to see if anyone else has this problem.
i havent check for any codes there, there are no vacuum leaks, and no on the throttle body.
It has a Apten ported blower with a 2.9 pulley, bassani x with maganaflow catback, and other odds and ends.
it only done it when the rpms droped like it was going back to idle but it didnt idle like i said it did it twice but then it didnt do it anymore but it does seem to be idleing a little lower than normal
Its the IAC. My 03 cobra started doing the same thing intermittantly about 4 months ago at 59,000 miles. I cleaned the IAC and it seemed to get better for about a day. Then started doing it again. I replaced the IAC two months ago and it has not died since. It won't throw a code.
11-10-2015 11:39 AM
