SVT Forums
Camshaft install and degree on 2001 Cobra Help
Old 06-20-2011, 01:12 PM
marine12001
marine12001's Avatar
Default Camshaft install and degree on 2001 Cobra Help
I have the passenger side head back on and and need to install the camshafts
and junk back on.
Its in TDC now and and just need to make sure the camshafts are in the correct position.
With #1 piston in tdc how should the camshaft dots line up? Im a bit confused on the diagram and such. I have also read the camshaft dots should both be pointing straight up??
Also when does the camshaft lock come into play?
marine12001 is offline
Old 06-20-2011, 11:36 PM
SVTeeshirt
SVTeeshirt's Avatar
and junk back on.
thats a weird diagram, its showing the timing marks/ angles aren't the same for ps and ds cam... kinda weird, idk if thats how it is for the 99/01s i have a full timing diagram and directions that are pretty indepth but its for the 96-98s, let me try to find one for the 99/01s.
SVTeeshirt is offline
Old 06-21-2011, 06:36 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
with #1 at tdc the crank keyway will point towards the passenger camshaft sprocket. Keyway will be @ 45* left of "straight up"
WhiteFoxGT is offline
Old 06-21-2011, 06:45 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
My internet explorer has gone full retard at the moment but when it comes back I'll get you the entire pdf file with full instructions and pictures.
Granatelli Sales
01-20-2020 12:34 AM
11-10-2015 11:39 AM
97SN95GT
09-13-2015 09:45 PM
Luke9222
09-04-2015 06:46 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Camshaft install and degree on 2001 Cobra Help
