03 Cobra heads/cams swap - pics!
My 03 Cobra had developed the infamous "head tick", so a few weeks ago I took her down to Street Lethal Performance in Edinburg, PA. By far, the best shop I have ever dealt with, hands down. The guys are incredibly knowledgable, extremely thorough, and they do awesome work. A little history on my Cobra - I bought it a year ago from a guy in Wisconsin with 37,000 miles on it. It was modded, and proven good for 520rwhp with the dyno graphs in hand. Since then, it has been to hell in back. After the 500 mile trip home, things just began to go wrong. First it was the supercharger - I was told it was a stage 4 port from a reputable porting company, but after removing it, it seems like it was a home-job. The unit made absolutely horrible noises, and after taking the casing off, it seems like it was ran without oil at some point! So, I bought a stock eaton with 9,000 miles on it and did a pulley swap. The chip that was for the port was no longer good, so I had to reflash the ECU with a diablosport tuner. After running the car for maybe 200 or 300 miles, the cylinder heads began ticking pretty noticably. So I bought 04 heads off a guy in Chicago, which are the revised, non-ticking units. Since I was planning on having the heads swapped, I figured I'd have the cams done in the mean time too. I bought stage 2 supercharger cams from MMR to do the job. While all this was going on, I dealt with a few annoying incidents... one of which was a severed clutch cable - not fun. Anyways, I made the drive down to Edinburg, and this is the progress made so far! Street Lethal discovered a few issues - the intake manifold was cracked (they're rewelding it for free), one side of the IRS was installed in a really poor manner (I was in danger of a shock coming completely undone), and the input shaft in the transmission may be messed up (this is TBA, but the clutch is super heavy, even for a stage 3). Well, as you'll see below, a few other problems include snapped bolts, a vacuum hose issue, and a plastic tab in danger of falling into one of the ports on my heads - good thing that didn't happen! Anyways, I will update with more information as I find out. A dyno video will eventually be here as well
My mess before work
this is where I was having vacuum issues
snapped bolt on the lower manifold
the plastic tab - stranger danger!
My mess before work
Cheers!
haha yeah I'm just fixing what's broken... which is a lot
11-10-2015 11:39 AM
Dan04COBRA
09-30-2015 11:46 AM
jaiidutch
09-14-2015 10:29 AM
