Rear coil spring question
I just picked up my 99 Cobra not too long ago. The back end sits really low and the front not so much. The springs are still very soft so my guess is they are cut stock springs.
My question is what springs from other models will work? I heard that Bullitt springs are about a 1" drop from stock
Bullitt springs wont work, it has a solid rear axle, and you have a irs. The springs are set up differently so you will need 99, or 03/04 cobra springs only. You can either find some stock springs that are uncut used for cheap, get some aftermarket ones online, or try cutting the front to even it out.
