6th gear problems in 04 cobra
Heres the deal, I own a 2004 Cobra and I just had a new Spec 2+ clutch installed. A week later it is popping out of 6th gear and when the car warms up, the clutch pretty much stops working. I have to hard shift it. I never had any problems until I upgraded my clutch. It has 75000 miles on it, Thanks.
Did you replace all the bearings when you did the new clutch? Or are the stock ones still on and you just put the clutch in?
Ya I had the bearings replaced.
might be the wrong pressure plate or something?? if you have a a short shifter make sure that your you stop blocks arent set to far in
Stock clutch quadrant?
