SVT Forums
Cobra motor tech info/assistance
Old 06-29-2013, 07:25 AM
sweet99
sweet99's Avatar
Default Cobra motor tech info/assistance
I just bought a '99 GT drop top that has an '03 Cobra motor in it. I need basic info such as number of quarts of oil it takes. Oil suggestions. SC oiling? Where/how to check/miles before change? Motor redline.
It has 42lb. injectors. A 95mm Delta Force MAF, 2.8"upper pulley, Fluidyne heat exchanger, Prochamber mid-pipe abd Pypes mufflers. I was told it makes 470rwhp but I doubt it is that much but it is strong and brakes the tires in 2nd easily.
I would like to start a relationship with some guys willing to help with this set-up.
It has a T-45 tranny and I am not sure about the cluitch adjustment. It has an MM firewall adjkusyer and I thought the clutch was slipping so I turned it in a little and it seems OK but I can lift the clutch pedal with almost an inch of play there/normal? That's a start. Thamks, Mark
sweet99 is offline
firehorse02
11-16-2015 11:28 AM
88 orangepeel notch
10-05-2015 09:03 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
logan409
09-26-2015 07:43 PM
Quick Reply: Cobra motor tech info/assistance
