Lowering Kit - Suspension Help - Mustang Deal Gone Sour
Maybe look in to SS brake lines, and better pads, but they may not even be needed.
AK,
Years ago, I used to have custom springs made that would be slightly different "ONLY" in height, but carry the same weight. They could be used to raise or lower the front or rear with very little negative affect. I'm only looking at 2 inches at the most in raising the rear.
I think you'll love them. Not just quicker stops, but more consistent stops, less fade, etc.
For my inconvenience they have offered to give me the Ford Racing lowering kit (THIS ONE) for $1k or a check for $800. The $1k includes everything (parts, installation, alignment and off course everything will be under warranty).
I paid ~$500 all told to have the "Ford Racing Handling Kit" installed on my car along with brake ducts, Steeda sub-frame braces and braded brake lines. Plus alignment with me driving the car on track between adjustments to make sure it handles the way I wanted....I don't think they are giving you that good of a deal there.
However, I do highly recommend the handling kit. Once installed and setup for you (I like the car very neutral so I can rotate it with my right foot without it getting exciting until I want it to) the car is amazing. With the additional power from a supercharger I imagine you'll have a great deal of fun.
However, if you're mostly a drag racing type I'd suggest just putting on the Steeda Sub-Frame braces which will keep the rear planted when you launch. Those alone make the car feel faster. I wish I had done some before and after 1/4 times to see if there really is any difference. Oddly, the butt dyno says there is.
Good luck on whatever you choose. Sounds like you're going to have a great car.
ModBargains
13
06-30-2014 11:42 AM
Steve@CJPP
CJ Pony Parts
11-21-2012 09:04 AM
