2016 V6, want to add fog lights, louvers...and
Install completed for now.
Instructions state Fog lights can be turned on any time the car is running
Right now they only turn on when the lights are off
So something is wrong
Instructions need to be updated
There is now way/no room to pus the wiring firewall plug back in
You can't reach it
Put the wiring thru a new hole in the firewall plug & pull it back into place
I had to use a coat hanger to thread the wire thru
Wire to connect to the fuse is not very tight, even after crimping
No light to indicate they are on ??
HUGE FAIL, an indicator light should have been made part of package
Easy enough to mount one under the dash somewhere
OR instructions on how to connect one should be provided
Will have to contact Starkey about the lights not going on except when switch is off
Cant say I'm impressed at all
You can't reach it
