LED grill help
Old 05-24-2018, 07:26 PM
BkissingK
BkissingK's Avatar
Default LED grill help
Hey everyone, so I just bought a 15 GT premium Friday. I'm on my second mod and I am lost. This LED grill didn't come with any directions and I just can't figure out the wiring. I've already got it installed at least. Any help is greatly appreciated. I'm not too concerned with the turn signals working just want the triangle LED to work all the time. Just a black/white/brown/green wire coming off that relay.
BkissingK is offline
Old 05-24-2018, 08:46 PM
08'MustangDude
Banned
08'MustangDude's Avatar
White should be voltage for the parameter LEDs, black ground, then the other two (+) triggers for
the LED signals.
White to Parking light power.
Black Ground
Then determine which color, BR & GN, is which side turn signal.
08'MustangDude is offline
Old 05-24-2018, 08:59 PM
BkissingK
BkissingK's Avatar
Ok, I’ll give that try. Thank you so much! Do u happen to know which wires (color) on the headlight harness I tap in to?
Old 05-25-2018, 03:08 AM
08'MustangDude
Banned
You want them on with the headlights, and not the parking lights?
Anyhow:
Relays 78 and 79 are for the headlamps, you can put the white wire
on the pin that sends power to the lights when the relay is triggered.
You can strip the wire about 1/4" back, insert it into the slot, then
push the relay back down in top of it:
That is a relay that comes on with the car, my white is actually a relay
trigger, so I am using the coil trigger slot for mine. Power comes from
the RED wire for me.
Old 05-25-2018, 05:11 AM
BkissingK
BkissingK's Avatar
Sorry I worded that wrong. I do want them on with the parking lights. This is a big help. I think I can finish this up now. Thank you again.
SyNdicateZ
AmericanMuscle.com
08-10-2011 10:34 PM
LamboStang05
03-31-2011 10:01 PM
So_Cali
AmericanMuscle.com
08-31-2007 09:27 PM
Daniel60
05-30-2006 01:48 PM
5.0V8
05-29-2005 01:42 PM
Quick Reply: LED grill help
