Steeda's 2015 Mustang Test - "No wheelhop"
Hello All:
I just wanted to pass this along, regarding our 2015 Steeda Mustang ... written & tested by Steve Turner of Mustang 360:
You can check out our upgrades here ... let's roll
The Mod List
Powertrain
Block: Stock Coyote 5.0-liter aluminum
Crankshaft: Stock, forged steel
Rods: Stock, sinter-forged connecting rods
Pistons: Stock hypereutectic
Camshafts: Stock
Cylinder Heads: Stock
Intake: Stock w/ Steeda Pro Flow cold-air intake
Fuel System: Electronic returnless
Exhaust: Stock w/ Steeda after-cat
Transmission: Stock Getrag MT-82 with Steeda urethane shifter and transmission mount bushings
Rearend: Stock IRS Super 8.8
Electronics
Engine Management: Tricor PCM w/ Steeda calibration
Ignition: Stock
Front Suspension
K-member: Stock
A-arms: Stock
Struts: Stock
Springs: Steeda Sport
Sway Bar: Steeda
Brakes: Stock
Wheels: Steeda ST-R, 20×9.5-inch
Tires: Nitto Invo, 275/35R-20
Rear Suspension
Shocks: Stock
Control Arms: Stock w/ Steeda adjustable toe link and billet vertical link
Sway Bar: Steeda
Brakes: Stock
Wheels: Steeda ST-R, 20×11-inch
Tires: Nitto NT-555R, 315/35R-20
However, what I overlooked is something I would never truly miss…
“No wheelhop,” he said flatly.
That’s right, laying into the Steeda Mustang produced none of the ill-effects you might associate with a rear-drive car with an independent rear suspension. However, it’s one thing to tame the suspension, it’s another thing to have the car still ride nicely. As we rolled onto the streets on the outskirts of Valdosta, Georgia, I followed the same loop that Jamie took me on. The car was clearly tighter than a stock Mustang but it was completely livable and quiet. Only the burble of the exhaust and a bit of communication from the shifter would penetrate the cabin.
The Mod List
Powertrain
Camshafts: Stock
Electronics
Ignition: Stock
Front Suspension
K-member: Stock
A-arms: Stock
Struts: Stock
Sway Bar: Steeda
Brakes: Stock
Rear Suspension
Shocks: Stock
Sway Bar: Steeda
Brakes: Stock
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
