Car wont go into fourth gear at 6000-7000 rpm
03-07-2017, 08:13 PM
Quote:
Originally Posted by
darkmach1
If you're at the top of 3rd and throw it in second the fuel cutoff isn't gonna save you. It will go to where 2nd gear rpm corresponds for that speed.
This is so true. But that engine won't willingly rev to 8K because of the limiter.
03-08-2017, 02:24 AM
Update: don't hear any sounds, car's still as fast, everything good then?
03-08-2017, 06:54 AM
is my username.
If the car seems to drive just fine like before then I'm guessing its fine.
03-08-2017, 07:23 AM
That is the beauty of overhead cam engines.
03-08-2017, 07:24 AM
proeagles
Can you explain that? I'm quite retarded when it comes to car internals.
03-08-2017, 10:00 AM
Do a compression test/leak down test
03-09-2017, 03:12 AM
darkmach1
Do the car services do that? Can I just request it?
03-09-2017, 07:08 AM
DarkRattle
The valves are in direct contact with the cams instead of push rods like in a Chevy V8, less moving parts, less to go wrong would be the simple answer.
03-09-2017, 09:38 PM
darkmach1
DarkRattle
Go to your favorite mechanic or shop, they will do it for you.
03-10-2017, 01:32 AM
darkmach1
How much does it cost?
