Exhaust system question
Hey yall pretty new so bare with me. Im looking at ordering a catback exhaust system most likely the borla s type stingers. Is there anything else i need with this when i go to the shop and get them to install it??
Thanks alott
Thanks alott
No, in these cars you have to change the whole pumpkin(diff) to change gears. Not worth it. Only way is if you find someone who wants your gears and you want his then even swap but it's a lot of work. If you're down there get a cradle lockout kit and vertical links from BMR suspension.
If you're not looking to overspend then a simple x-pipe with the resonator delete is cheap and sounds good.
Sorry if I sound stupid as I said im new to this stuff lol but does a catback system require a h or x pipe or does that come with it... because I want to replace everything and ive been looking at catbacks for awhile
Yes the "catback" starts just as the header reaches the bottom of the car. It will be either an x or h then all the way back. A decent fatback will cost you ~900 so I would suggest trying to pick one up used using the forums or coyote Facebook groups. It's just really expensive for piping that makes noise and adds no power.
