Guess my ET ?
Guess my ET ?
Going to the track this weekend for the first time.
elevation at track - ~400 ft.
temps predicted - high 60's / low 70's
driver mod - ehhhh.. im ok i guess.
never ran at a track, but know what i'm doing.
06 gt . . 5 speed with hurst. nitto NTRD1 tires on rear 255's. Will drop tire pressure because i spin like a ****, but what PSI should i set them too ? Also have Eibach Pro Kit installed
mods so far - FRPP 3.73 , JLT 3 with Xcal 3 brenspeed 93 oct. tune. steeda UDP.
any predictions ? thanks
I run my MT ET's at 13 lbs. You can grab a silver sharpie or paint marker then put a line on the rim/tire. Keep lowering the psi by a pound and make sure that the tire isnt spinning on the rim. If the notch is moving a lot, then you will probably need to add more psi. Im guessing youll run a 13.3 or 13.4 on your best ET. -Jon
why do u say so??
whole different world.......
__________________________________________________ __________________
What track???
with street tires dont do a big burnout, spin to clean is all u need.
Pressure 25ish is usually about the lowest u want on a street tire.
What track???
and the track is esta in cicero new york
