What do you think I can run with..
Ok, well pulling the trans this weekend and hope it's just the 3/4 shift fork so I will order everything to fix it, etc. I'm sorta wanting more powa.. So in the past on street tires I've ran in the 1/8 .. 8.3 @ 95 mph with 22/23 psi in every gear on 93. On my race gas tune I only ran WG spring pressure in 1st (it was like 13-15psi, can't remember exactly) 20-22psi in 2nd and 29psi in 3rd and I hit 8.3 @ 96 mph. Traps wasn't that much better due to all the boost reduction.
I'm wanting to go more when it gets cooler, and on slicks. I will be able to run 29psi in 1st-4th and I'm looking to throw a 50 wet shot on it in 3rd and 4th (2nd if it can handle it). Based on my previous traps what you you think the car is capable of in the 1/4 on full boost and nitrous? ET and MPH.
well seeing as how my '95 only trapped 91 in the 1/8, and yet ran an 11.8 as it's best. i would say that with this being a turbo car, and even without the nitrous, IF you can hook well i would say a low 11(11.1-11.3) at 125ish. then if you throw in a 50 shot i could see 10's for sure with a high 12x trap.
