how would i do
how would i do
finally have mods in my car. '06 gt 5 spd with steeda cai and a sct tune, running 93 octane from brenspeed. buddies little brother got a 2003 bmw m3 smg, he told me he wanted to run me. how would i do against him? we'll probably do roll races, i haven't gotten used to launching my car with the tune/cai because the wheels spin all the way through first. gotta work on that. we're gonna do a 40 roll, 60 roll and probably a 20-25 roll. any input is appreciated. thanks
Assuming he has nothing after market, down low you have a good bit more torque than him, horsepower is fairly even as is weight, if you guys aren't doing speeds over 120 you should take him with the torque advantage.
My guess is you are 335hp/330-340ish torque
He is 333hp/265 torque
thanks gt/cs, im glad to hear that i can take him now up until speeds increase over 120. we won't be doing anything that fast, most likely it'll be 40-80 or so. does the same go for an e39 m5 do you think?
Torque doesn't have as much to do with it as it's made out to. Gearing, power under the curve, and weight play a much bigger factor. My Granpa's tractor makes enough torque to pull over 300,000 lbs, but that doesn't mean its fast.
At any rate, you'll handle that year M3 just fine, dig, roll, shouldn't matter.
Who's gonna win? A npi gt would be lucky to get into the high 14's. The 370z is a solid mid 13's car.
Or compare a v8 M3 to the same 1996 gt. The M3 makes 414 horsepower and 290 ft-lbs. So, same torque but the M3 makes 200 hp more.
M3 can fly through the quarter a full 2 seconds faster than the 96 gt even though they have equal torque.
Or the same M3 vs a 99 gt. Gt has 302 ft-lbs. More torque. Would still get raped by the M3.
There's a multitude of factors that go into winning a race. Torque plays a role, but you can't just say "MORE TORQUE = WIN" as seen by the scenarios above
If you have traction, low end torque will help you off the line. After that, its two parts horsepower to weight, one part aero and one part gearing.
OP, up top I think you guys will be close but overall you have the faster car.
check this out:
http://www.youtube.com/watch?v=R1aDhG8APQs
mustang got a ****ty launch, started to pull towards the end
